Apr 20, 2005 #1 N Naz Junior Member level 1 Joined Feb 28, 2005 Messages 18 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,428 About FPGA? What should i do after assigning the Pin Package? When i Press RUN nothing happens. I am using SPARTAN3
Apr 20, 2005 #2 E echo47 Advanced Member level 6 Joined Apr 7, 2002 Messages 3,933 Helped 638 Reputation 1,274 Reaction score 90 Trophy points 1,328 Location USA Activity points 33,176 ABOUT FPGA? Please start from the beginning and tell us what you are trying to do, and what software you are using.
Apr 22, 2005 #3 T tongson Junior Member level 2 Joined Dec 24, 2004 Messages 24 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 159 ABOUT FPGA? pls check the information below the main window.
Apr 26, 2005 #4 S sxqzj Member level 4 Joined Feb 18, 2004 Messages 72 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 496 About FPGA? if you assign pin at the beginning of design ,then you may add constraint and synthsis the design ..
Apr 26, 2005 #5 B buzkiller Member level 4 Joined Dec 31, 1999 Messages 75 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,288 Activity points 602 About FPGA? The best way toassign pins is by using the PACE tool: **broken link removed**
Apr 27, 2005 #6 tkbits Full Member level 5 Joined Dec 4, 2004 Messages 242 Helped 39 Reputation 78 Reaction score 2 Trophy points 1,298 Activity points 2,209 Re: About FPGA? Naz said: What should i do after assigning the Pin Package? When i Press RUN nothing happens. I am using SPARTAN3 Click to expand... What's RUN ? A button on the screen or a pushbutton on your board ? You haven't said anything about synthesizing (building) your design, nor about transferring the built design to the FPGA (known as programming, configuring, or downloading).
