What shall I do to stablize the Vcon of VCO to make my PLL work well?
eda_range
Member level 1
Member level 1
Hi
My PLL ckt works well in 125°, but while the temperature decending to -40° the ckt can not lock the freq and phase.
thank you
Re: a problem on PLL
please post your circuit of VCO... i mean post the circuit of the parts which show variation in output due to temperature,,,....
Did you try thermister or use negative temperature coefficient cap. for temperature compensation ?
Rogernt
You didn't give many details, but check the harmonics of your VCO at the colder temperature. Some PLLs that don't have harmonic-locking problems at room temperature can develop them at high or low temperatures when the VCO's behavior changes.
Also look for issues with moisture condensation. Clean the board thoroughly.
eda_range said:
Hi
thank you
your PLL phase margin is not good, you can increase the PLL open loop phase margin.
