Enlightenment
Full Member level 3
- Joined
- Jul 26, 2006
- Messages
- 174
- Helped
- 29
- Reputation
- 58
- Reaction score
- 23
- Trophy points
- 1,298
- Location
- 3rd Rock From Sun
- Activity points
- 2,672
What lead-spacing do you use for lower-capacitance radial thru-hole capacitors on PCBs? For example, bypass capacitors and smaller electrolytic / tantalum capacitors that are being used for logic-voltage power.
There are many lead-spacings, so I was curious what spacings other people use, so I can add at least 1 or 2 extra holes for more choices for hand-building PCBs. Obviously the wider lead-spacing is not for low-values, but I listed them below anyway.
Various sizes that I've seen: 1mm, 1.5mm, 2mm, 2.5mm, 2.54mm, 3.5mm, 5mm, 5.08mm, 5.1mm, 6.35mm, 7.5mm, 10mm, 10.16mm, 12.5mm, ...
