What is the use of codec in signal processing?
janakiram.sistla
hi all
please clarify me what is the use of codec in signal processing
Re: doubt on codec
what do you mean?
For transmissing data in limited bandwidth, right?
Re: doubt on codec
hi
please any one can explain me the functionality of codecs
doubt on codec
hai...
Coder + decoder = CODEC
Codec is a single chip device which i s used to interface a DSP processor system to the outside world..
It mean .. it has both ADC and DAC... so that signals can go in/out of a processor...
_helios
hi.raj.tripod.com
doubt on codec
Hi
to input and output analog data to/from DSP processor u need a gate. Certainly this gate should have ADC and DAC and codec blocks(ICs) for DSPs are such blocks and some of them have anti-aliasing filters in their ADC.
for detailed info u should ask a more deliberate question.
cheers
Re: doubt on codec
Hi All,
Codec is a portmanteau of either "Compressor-Decompressor" or "Coder-Decoder," which describes a device or program capable of performing transformations on a data stream or signal. Codecs can both put the stream or signal into an encoded form (often for transmission, storage or encryption) and retrieve, or decode that form for viewing or manipulation in a format more appropriate for these operations. Codecs are often used in videoconferencing and streaming media solutions.
you can read more about this at : https://en.wikipedia.org/wiki/Codecs
cheers...
