swordfisherman
Newbie level 3
the problem is these memory only occupy limited space of the memory space,so when not access, all 3 DOUT will be Tri-state, which is not good because it use internally, Tri-state can cause learkage issue. if I have a decoder always enable one BANK, since the all OEN enable almost switch the same time, it might happen one channel one channel DOUT is High, another is LOW, therefore there are some shoot through, I have heard we need add some deadtime in between?
here is my doubts:
1. keep internal floating,if solve the shoot through issue, but how to solve the Floating issue
2. keep one bank enable by default, solve the Leakage issue, but it cause shootthrough
3. if solve by adding deadtime, it look like we have to do it in the layout level
thanks
here is my doubts:
thanks
