What is the postscaler in PIC used for?
seyyah
Advanced Member level 2
What is postcaler, which is used in pic timers, for ?
postscaler pic
The postscaler is used to extend the time period that a timer can generate.
If you set the postscaler to 4 for example you will get four times the timeperiod the timer can generate normally.
I use this often to get a lower frequency of an interrupt for example.
hope this helps
Re: (pic) postscaler and difference to prescaler?
another answer may help
