ElectricalEngineer
Junior Member level 1
I am trying to get an idea of what the output impedance of this circuit would be. First off, the harmonic termination is terminated with a 50 Ohm resistor (Rh) Lh and Ch are parallel resonant at the output frequency.
LPF Characteristic impedance would be 50 ohms.
My theory is that Rh would dominate as the impedance of the system and be less dependent on the switch characteristics, however, my other theory is that is mainly depends on the switching current from the Lchoke back EMF. I also know that the voltage at Lh/Ch resonance can be much greater than VDD which makes me think it's mostly dependent on Rh.
Can anyone shed light on this and help me understand what the impedance of a system like this would be?
The picture of the example was taken from the Si446x application note AN648 and is figure 17.
