Jul 13, 2020 #1 U unbuildpain Full Member level 2 Joined Jul 11, 2020 Messages 145 Helped 0 Reputation 0 Reaction score 3 Trophy points 18 Activity points 968 What is the main difference between a 5GHz antenna and a 2.4GHz antenna? Is it the winding or material? Is there anything I can make which would work with any frequency?
Jul 13, 2020 #2 V volker@muehlhaus Advanced Member level 6 Joined Apr 11, 2014 Messages 3,193 Helped 1,071 Reputation 2,146 Reaction score 1,142 Trophy points 1,393 Activity points 20,282 If you think of separate antennas: For 5 GHz, wavelength is smaller and the antenna is a scaled-down (smaller) version of the 2.4GHz antenna.
Jul 13, 2020 #3 FvM Super Moderator Staff member Joined Jan 22, 2008 Messages 52,420 Helped 14,749 Reputation 29,780 Reaction score 14,101 Trophy points 1,393 Location Bochum, Germany Activity points 298,099 Depends on the antenna type. 2.4 + 5 GHz is often designed as dual band antenna, e.g. for WiFi. Wideband antenna is more complicated, it will have considerably larger size, e.g. log.per. dipole.
