FPGAs have optionally controlled CCLK speeds. XC4000 devices
can generate a configuation clock (CCLK),used to clock
configuration data to the device when operating in master mode,
at two different speeds. In the default slow mode, frequency
ranges from 0.5MHz to 1.25MHz In FAST CCLK mode, the frequency
will range from 4MHz to 10MHz. The XC4000X family FPGAs can run
as fast as 15MHz when in fast mode.
the frequency of CCLK in master mode is determined by your bitgen settings when you biold the bitstream. The clock starts out at the
default, 2.5 MHz IIRC, and when the frequency selected by bitgen has been transferred to the part, the CCLK frequency changes. Note that it is
possible to request CCLK frequencies higher than the capability of the XCF prom, and you need to use the maximum CCLK frequency when determining
your highest usable clock speed, not the nominal frequency selected for bitgen.
