What is the error in this small "c" program ??
iscore
Junior Member level 1
Hi ..I have written a c program to display 4 numbers, each on a 7 segment display(1 segment for 1 digit).. I am using input keys , 80c51...I am writing the code in keil...According to my logic, it should take 4 values through input keys one after the other and display them in their respective 7 segment displays as soon as key is pressed....And the execution should be finished after the 4th digit is displayed...Because i am not writing the program inside "while(1) " loop...I am using a switch which is always '0'(closed)...
But the problem is, when i simulated the code in keil and proteus, after displaying the 4th digit, it again goes back and displays the 1st digit, then 2nd and the process never stops(But i need it to happen only once)...Kindly help me in finding where the error is ....I have attached the program...
		  #include<reg51.h>
unsigned char sec=00;
unsigned char min=00;			/* initial minutes value which is displayed at the start*/
					/* initial seconds value which is displayed at the start*/
unsigned char sec1,sec2;
unsigned char min1,min2;
unsigned char delay=0;
unsigned char array[];
unsigned char sec1=0,sec2=0,min1=0,min2=0;
unsigned char demux=0x00;
unsigned char count=0,display=0;
/*unsigned char flag=0;*/
unsigned int i=0;
unsigned char j=0;
unsigned char value1=0x00,value2=0x00,value3=0x00,value4=0x00;
#define set_time P3
#define display_time P1
#define time_demux P2
sbit s1=P0^0;
sbit s2=P0^1;
void manual_input();  /*function to give manual time settings */
void delay_subroutine();
	void main()
	 	s1=1;	  /*pause button making it input */
	  s2=1;
	  set_time=0xFF;
	/*  IE=0X82;
	  TMOD=0X01;
	  TH0=0XEE;
	  TL0=0X00;	*/
	  	/*port through which you set time.making it input*/
		  manual_input();
		do
         delay_subroutine();
		     time_demux=0x0F;
			 time_demux=0x00;
			 display_time=sec1;
			 delay_subroutine();
			 time_demux=0x0F;
			 time_demux=0x01;
			 display_time=sec2;
			delay_subroutine();
			time_demux=0x0F;
			time_demux=0x02;
			display_time=min1;
			time_demux=0x0F;
			time_demux=0x03;
			display_time=min2;
			 delay_subroutine();
			 } while(s1==0);
/* void timer0 () interrupt 1
{	 TH0=0XEE;
	 TL0=0X00;
      flag=1;
	  display=display+1;
	  if(display==4)
	    display=0;}
	  void manual_input()
		while(count<4)/*  this is because you have 4 values to enter	*/
	     	  while(i<3000)	  /* a small delay during which any initialkey press is released*/
			  {	i++;
				i=0;
		        if(set_time==0XF0)
				  while(i<=45000)	/*for this duration of time the value from port3 connected to output of encoder is takenand stored in array*/
				     array[j]=set_time & 0x0F;/*masking last four bits and taking only the first four because that gives binary equivalent of number pressed */
					 i++;
					   time_demux=demux;   /* activating  demux and selecting the seven segment displays*/
					 display_time=array[j];/* displaying the value entered*/
					   i=0;	 }
					 demux=demux+1;		/*incrementing demux value so that control goes to next segment and next digit for timeis entered and displayed on the corrsponding display */
					    j++; /*incrementing index of array */
					   while(i<=45000)
			  {	 i++;
				   i=0;
				count++;
							   } sec1=array[0];
							     sec2=array[1];
								 min1=array[2];
								 min2=array[3];
			  while(delay<=2)
			    delay++;
  • code.txt
hey i have not read your code but if you want to just display it just once,then in the end of main()
just write
while(1);
i.e
void main()
your code
while(1);
and check it out.
Also try to post your code in code tags (the # sign on top) instead of attching it.
I've inserted the code contained in your attached text file within your initial post.
It appears the last routine is incomplete, missing one or more curly brackets.
BigDog
i dont think there are missing curly brackets as when i comppiled it build was successful
