#include<reg51.h>
unsigned char sec=00;
unsigned char min=00; /* initial minutes value which is displayed at the start*/
/* initial seconds value which is displayed at the start*/
unsigned char sec1,sec2;
unsigned char min1,min2;
unsigned char delay=0;
unsigned char array[];
unsigned char sec1=0,sec2=0,min1=0,min2=0;
unsigned char demux=0x00;
unsigned char count=0,display=0;
/*unsigned char flag=0;*/
unsigned int i=0;
unsigned char j=0;
unsigned char value1=0x00,value2=0x00,value3=0x00,value4=0x00;
#define set_time P3
#define display_time P1
#define time_demux P2
sbit s1=P0^0;
sbit s2=P0^1;
void manual_input(); /*function to give manual time settings */
void delay_subroutine();
void main()
s1=1; /*pause button making it input */
s2=1;
set_time=0xFF;
/* IE=0X82;
TMOD=0X01;
TH0=0XEE;
TL0=0X00; */
/*port through which you set time.making it input*/
manual_input();
do
delay_subroutine();
time_demux=0x0F;
time_demux=0x00;
display_time=sec1;
delay_subroutine();
time_demux=0x0F;
time_demux=0x01;
display_time=sec2;
delay_subroutine();
time_demux=0x0F;
time_demux=0x02;
display_time=min1;
time_demux=0x0F;
time_demux=0x03;
display_time=min2;
delay_subroutine();
} while(s1==0);
/* void timer0 () interrupt 1
{ TH0=0XEE;
TL0=0X00;
flag=1;
display=display+1;
if(display==4)
display=0;}
void manual_input()
while(count<4)/* this is because you have 4 values to enter */
while(i<3000) /* a small delay during which any initialkey press is released*/
{ i++;
i=0;
if(set_time==0XF0)
while(i<=45000) /*for this duration of time the value from port3 connected to output of encoder is takenand stored in array*/
array[j]=set_time & 0x0F;/*masking last four bits and taking only the first four because that gives binary equivalent of number pressed */
i++;
time_demux=demux; /* activating demux and selecting the seven segment displays*/
display_time=array[j];/* displaying the value entered*/
i=0; }
demux=demux+1; /*incrementing demux value so that control goes to next segment and next digit for timeis entered and displayed on the corrsponding display */
j++; /*incrementing index of array */
while(i<=45000)
{ i++;
i=0;
count++;
} sec1=array[0];
sec2=array[1];
min1=array[2];
min2=array[3];
while(delay<=2)
delay++;
