Jun 9, 2009 #1 glenndr_15 Member level 1 Joined Mar 27, 2009 Messages 34 Helped 3 Reputation 6 Reaction score 2 Trophy points 1,288 Activity points 1,455 max232c What is the difference of MAX232 to MAX232C? Best regards, glenndr_15
Jun 9, 2009 #2 H hakeen Full Member level 5 Joined Jun 16, 2005 Messages 240 Helped 44 Reputation 88 Reaction score 19 Trophy points 1,298 Activity points 2,783 what is max232 At least the working temperatures are different: MAX232C has 0°C-70°C (office), whereas MAX232E has -40°C to 85°C (industrial). PS. 232A is also 0°C-70°C, but data rate ability is up to 200kbps. Hope helps. Cheers
Jun 9, 2009 #3 E engr_najam Full Member level 2 Joined Aug 10, 2006 Messages 128 Helped 7 Reputation 14 Reaction score 1 Trophy points 1,298 Activity points 1,939 max232c max232 MAX232C have built in capacitors. while for with MAX232, you have to connect two or three capacitor for its proper operation.....
Jun 10, 2009 #4 glenndr_15 Member level 1 Joined Mar 27, 2009 Messages 34 Helped 3 Reputation 6 Reaction score 2 Trophy points 1,288 Activity points 1,455 max232 industrial you mean guys thier difference is in physical construction? interms of operation they are the same?
Jun 10, 2009 #5 E engr_najam Full Member level 2 Joined Aug 10, 2006 Messages 128 Helped 7 Reputation 14 Reaction score 1 Trophy points 1,298 Activity points 1,939 max232e vs. max232c yah, both are using for interfacing microcontroller with serial port RS232. u will need only extra capacitor in case of max232. i hav used both ICs myself
