[SOLVED] what is the difference between real and realtim in verilog
aquakeerthi
Junior Member level 3
coimbatore,India
i would like to know friends the different between register data types of real and realtime pls urgent
ime is a 64-bit integer type value, which will always ignore fracional part. Whereas, realtime can store a real value for simulation time.
As you may be knowing, Verilog has inbuilt system tasks $time and $realtime. $realtime gives the real value of time. However, the precision depends on the timescale precision value.
According to time-precision value given, the simulator will round off the simulation time value given by $realtime.
For example, `timescale 10ns/1ns implies that the time will be having precision upto one digit after decimal point.
hIII...
Thanks for your answer but please note that the question is not difference between $time and $realtime
IT is between real and realtime........hence please post proper answer
Real is like double in C/C++ which has 8bytes size,1023 expoenet and 52 -bit mantisa,range is 1.7E-308 to 1.7E+308,with atleast 15 digits of precision while realtime is identical to real but it will give time value based on the `timescale precision
