What is the difference between NPN and PNP bipolar transistor?
npn vs pnp explanation
Positive and negative Vbe from application point of view?
what does npn vs pnp mean
chuan556 said:
Hi all,
May i know what is different between NPN and PNP bipolar transistor?
Thanks
Not much difference. NPN is just a counter part of PNP. PNP is triggered with a negative signal while NPN is triggered with a positive signal That is why there is a class B amplifier which is more efficient that class A because it uses the signal itself to turn on the transistor and amplify the signal. If you are going to use it as a switch, you must have a negative signal to the base of a PNP transistor in order to turn it on while a Positive signal to the base of a NPN transistor so that it will turn on. Hope this one help you not confuse you.
Regards,
Necolei
