what is the difference between 3d and 2d field simulation?
THUNDERRr
Full Member level 3
difference between 2d-simulator
by example please
ali110
Full Member level 1
difference between 2d and 3d simulation
Hi THUNDERRr
In 2D simulation planar structures such as microstrip structures can be analyzed but in 3D simulation both planar and nonplanar structures such as waveguides, Horn antennas,.. can be analyzed. in later the meshing is based on 3D segments
I hope it'll be helpful
Manjunatha_hv
Advanced Member level 3
INDIA
Hello,
In 2D Field Solver it Computes Fields (say currents) in a Cross-section (X-Y plane)
so only meant for planar structures takes less computational effort (Memory & Time)
In 3D Field Solver it Computes 3D Fields in all directions and Currents Surrounding/On Arbitrary 3D Objects
good for Waveguides, etc but takes lot of computational effort (Memory & Time)
So people try to use 2.5D or 3D Planar Field Solvers to quickly & acceptable accuracy analysis
where it can handle Multilayer dielectrics & Vias
such solver examples are Sonnet em, Agilent Momentum, AWR AXIEM, Zeland IE3D, etc
See here more on this topic "Which EM Analysis Should I Use?"
https://www.sonnetsoftware.com/videos/apreso/Which EM Analysis Should I Use.htm
---manju---
THUNDERRr
Full Member level 3
difference between 2d and full 3d sim
is there something called 1 D simulation?
Manjunatha_hv
INDIA
difference between 2d and 3d objects
Hello,
yes...1D is just equations or formulae or equivalent models...
Again see the attached documet ...
---manju---
