Well, one theory could say that EIRP is one of our moderator buddies, but here http://www.csgnetwork.com/antennaecalc.html you can find a more comprehensive definition of Effective Isotropic Radiated Power, and some tools to calculate it from the antenna gain and the actual transmitted output power.
EIRP is a measure of approximate power radiated from an antenna.
The approximation works well as it considers almost all possible factors.
Say an antenna is capable of transmiting P power..(Watts) ,then this P is not actually transmited.
Consider the various losses and we can get actual power radiated.
For simplicity ,EIRP is calculated in Log system as losses can be directly substracted from net power.
EIRP= P - Losses.
EIRP is directly proportional to antenna gain.
EIRP is most important parameter while designing various systems. (say a satellite link )
Well, one theory could say that EIRP is one of our moderator buddies, but here h**p://www.csgnetwork.com/antennaecalc.html you can find a more comprehensive definition of Effective Isotropic Radiated Power, and some tools to calculate it from the antenna gain and the actual transmitted output power.
The Effective Isotropic Radiated Power (EIRP) of a transmitter is the power that the transmitter appears to have if the transmitter were an isotropic radiator (if the antenna radiated equally in all directions).
By virtue of the gain of a radio antenna (or dish), a beam is formed that preferentially transmits the energy in one direction. The EIRP is estimated by adding the gain (of the antenna) and the transmitter power (of the radio).
EIRP = transmitter power + antenna gain – cable loss
path loss is not included in measuring EIRP, coz EIRP is effective power radiated by antenna, this is transmitter's power(dB) + antenna gain (dB). Path loss is experienced by the radiated power, so path loss is an external factor of lossess.
