What is syndet brkdet ion 8251a concept and its functionality?
azzintani
Newbie level 6
usart pin
SYNDET/BRK pin outputs a High to indicate the chip has detected the SYC. Characters in Synchronous mode with internal syc. enabled ;or, it has detected a break condition ( RX line remained low for minimum two character periods ) in the Asynchronous mode. If in the synchronous mode, external syc. option is selected, this pin is an input pin and the external circuit should apply a high level when a syc. condition is detected.
Regards,
Laktronics
programming of usart 8251
whats the benefit of loading the syn characters in syc mode ?
regards
8251 a pin description
Since in synchronous mode there is no Start bit as in asynchronous mode, you use special sync characters to identify the start of frame and there after to locate the data bits from the frame.
Regards,
Laktronics
