What is "no convergence in operating point" in Hspice?
letan
Member level 3
VietNam
What is "no convergence in operating point" in Hspice? Who can help me, please?:cry::cry:
try changing from trapeziodal to gear2 for the algorithm to be used by the simulator. Hspice uses trapezoidal as default. JUst google for the specific command.
Thanks
Amarnath
no convergence in dc sweep curves at
Thanks amarnath!
Can you tell me what is "no convergence in dc sweep curves at 1.5" error? I am simulating in range of temperature: -40, 27 and 110 degree, and with corners: TT, SS, FF, but have corners no error. Why?
no convergence in dc sweep curvers at
Read the document and find out
hspice error 11
hi letan can you post your netlist and corners files...i would like to see them once before i could comment. Usually u can change the algorithm the simulator uses by giving a command , which i cannot recollect, i suggest you take a look at hspice command reference pdf and search for gear2
amarnath
**error** no convergence in operating point
Could you try these:
.option gmin=1e-9
.option gmindc=1e-9
See if it help. If it does, then read the menu about the meaning for these setting.
hspice error code 11
hi, try to change simulator option again and again to achieve convergence.
