What is inside a car shock/impact sensor?
pradeep_k_b
Full Member level 3
Nilambur, India
Hi ,
I was trying to make a shock sensor.My idea was use a small condenser mic and detect the vibrations,and of course it works.But when I need to cover a large area for example 1mx1m area its difficult .Then I searched for the shock/impact sensors that used in old cars(I am not sure this is the same in new cars as well,but in new cars there are using many other sensors I think) .And I got a couple of product details and also some installation videos etc.But I couldn't find out how its working.Its just a box and it can detect the hit on the car
This is one of the product https://www.amazon.com/Directed-Ele...dz-20&linkId=baf74d29cd9fe926ab993b086dedec9d
And its an installation video https://www.youtube.com/watch?v=ri03oBDwpFE
Anyone know what is inside that box? is it just a piezo sensor or a mercury tilt switch? then how it detecting any hit on the car using a single sensor?
Looking forward to your feedbacks
Thanks,
Pradeep
It says right there: "Uses patented electromagnetic technology".
It DOES NOT say it uses a piezo; it DOES NOT say it uses a mercury tilt switch.
Probably uses something like a ferrite rod that flops around inside a coil. But why do you care? If you really want to know, it looks easy enough to open.
From what I read about car systems, they use accelerometers to detect things like crashes for deploying the airbags and such. Old style car alarms used to use shock sensors (to detect things like windows being broken) can't tell you how many times back in the day that somebody on a Harley would rev their engine in a parking lot to set off all the shock based sensors of everybody who had a car alarm. Pre airbags I don't recall any kind of shock/accelerometers (other than possibly an engine knock sensor) used in cars, at least none were in any of the old shop manuals I had for cars I owned back then.
Okay.Thank you very much for your comments
But I am still curious about how they are achieving this by just connecting a small box under the dash board.I couldn't find any sensing element and all they are connecting a box only.If if detect the vibration ,the received vibration level will be different,right?.For example if someone hit on the back of the car there will be only a small vibration on the from dashboard
I think you have difficulties to understand elementary law of mechanics. A car is a more or less rigid structure. If it's massively bumped, the acceleration can be sensed at any part of the chassis.
I think there are more sensors rather than "just 1 box" in modern cars.
You are just trying to build a prototype or proof-of-concept right?
Why don't you try using 3 sensors placed 30cm apart, which each of them having the ability to trigger the main ckt when vibration is sensed.
You are correct..Thank you
May be that will work if I try to do that.But in end product I need to cover 1m with one sensor
You don't say what you're trying to sense, or why. If it's a rigid system, then you should be able to detect shock with a single sensor; if it's less than rigid, then you'll have problems (try pushing a rope). You don't say if you're just looking for the occurrence of ANY shock, or if you need more information from your measurement.
