gen0357 said:But if you want to balance the skew. Simple option is to use the CTS algorithm, instead of specifying clock, specify the HFN net & encounter will build the buffer N/W to meet the specified skew requirement.
zhipeng said:gen0357 said:But if you want to balance the skew. Simple option is to use the CTS algorithm, instead of specifying clock, specify the HFN net & encounter will build the buffer N/W to meet the specified skew requirement.
Could you elaborate on that? In Encounter, if I have a signal (output of a previous DFF register) which needs to fan out and to drive SE pins of many SDFF registers, how should I tell Encounter to meet skew requirement? Thank you very much!
