what is Hercules Bundle (DRC/LVS/ERC/MW)
tybhsl
Member level 1
erc, drc
I have no idear of what is Hercules Bundle (DRC/LVS/ERC/MW) but it is a eda tool used for physical verification. Who can tell me in more details about it? And what is DRC/LVS/ERC/MW respectively? Thanks!
hercules drc
Hercules is a signoff tool.. kinda very powerful tool.. i shall try to get some documentations..
h**p://www.hhnec.com/web-e/foundry/ref1_1.htm
take a look at the above link wud surely help.
with regards,
erc lvs drc
DRC: Design Rule Check, example W/L check and distance of bewteen Metal etc.
LVS: Logic verify Schematic
ERC: Electric rule check
lvs in hercules
Then what does it mean by MW? Thank you!
Added after 5 hours 14 minutes:
with regards,
Yes, it is quite helpful to me! Thanks a lot!
Who can tell me some more books or documents about Hercules Bundle ? Thank you very much!
erc drc lvs
Tanks! And who can tell me what's MW? Thank you very much!
hercules drc lvs
maybe "milkyway".
Added after 3 minutes:
the database.
what is drc, lvs, erc
Who have the datasheets or documents of Hercules Bundle (DRC/LVS/ERC/MW)? I need them greatly. Who can help me. I look for them in Internet in vain and I do hope you can help me! Thanks a lot!
hercules lvs
Where can I find some documents about it? And what's ERC? What's the difference between ERC and DRC? Thanks!
I only have a brief view....
DRC is design rule check while ERC is electronic rule check. ERC will check IR drop,antenna,EM(electronic migration) effect in your chip which will not be checked by traditional DRC process.
I also have the same problem,thanks a lot if someone can provide some documents!!
