what is GPIO_ResetBits ?
aliyesami
Full Member level 6
Full Member level 6
USA
I am trying to use the ILI9340 TFT display by Newhavendisplay and its giving an example code for this display as follows :
Iam trying to write an AVR code for this LCD so if anyone can help me out .
thanks
2.4in_TFT.c
Program snippets for writing to Newhaven Display 2.4" TFT with ILI9340 controller
(c)2010 Curt Lagerstam - Newhaven Display International, Inc.
 	This program is free software; you can redistribute it and/or modify
	it under the terms of the GNU General Public License as published by
	the Free Software Foundation; either version 2 of the License, or
	(at your option) any later version.
	This program is distributed in the hope that it will be useful,
	but WITHOUT ANY WARRANTY; without even the implied warranty of
	MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
	GNU General Public License for more details.
* Function Name  : TFT_24S_Write_Command
* Description    : writes a 1 byte command to 2.4" TFT.
* Input          : command = one byte command (register address)
* Output         : None
* Return         : None
void TFT_24S_Write_Command(unsigned int command)
GPIO_ResetBits(GPIOC, CS1);
GPIO_ResetBits(GPIOC, RS);
GPIO_SetBits(GPIOC, nRD);
GPIO_ResetBits(GPIOC, nWR);
GPIO_Write(GPIOB, command);
GPIO_SetBits(GPIOC, nWR);
TFT_delay(10);
* Function Name  : TFT_24S_Write_Data
* Description    : writes 1 byte of data to 2.4" TFT.
* Input          : data1 = one byte of display data or command parameter
* Output         : None
* Return         : None
void TFT_24S_Write_Data(unsigned int data1)
GPIO_Write(GPIOB, data1);
GPIO_SetBits(GPIOC, RS);
* Function Name  : TFT_24_9340_demo
* Description    : Loads bmp from SD card and writes to NHD-2.4-240320SF-CTXI#-1.
* Input          : None
* Output         : None
* Return         : 1-end of function reached
int TFT_24_9340_demo(void)
char filename[18] = "2_4_240320SF_";
char filetype[4] = ".bmp";
char filenumber[1] = "0";
int i,n,result;
char image = 0x30;
unsigned short RGB16[25600];
unsigned char red,green,blue;
UINT blen;
GPIO_ResetBits(GPIOC, IM0);		//16-bit mode
memset(RGB16,0x0000,sizeof(RGB16));
TFT_delay(100);
TFT_24_9340_Init();
TFT_delay(100);
filename[13]='\0';
filenumber[0] = image;
strncat(filename,filenumber,1);
strncat(filename,filetype,4);
while(1){
TFT_24_9340_Init();
UILCD_SetCursor(0,0);UILCD_DisplayString("Reading SD Card ");UILCD_SetCursor(1,0);UILCD_DisplayString("                ");
UILCD_SetCursor(1,0);UILCD_DisplayString(filename);
if(openSD(filename)==0x30)
	{while(1);}
seekSD(54);
TFT_24S_Write_Command(0x002C);				//Memory write
for (n=0;n<3;n++){
	for (i=0;i<25600;i++)				//for each 24-bit pixel...
		f_read(&File1, &blue, 1, &blen);	//read the blue 8-bits
		f_read(&File1, &green, 1, &blen);	//read the green 8-bits
		f_read(&File1, &red, 1, &blen);		//read the red 8-bits
		red=red>>3;				//shift down to 5-bits
		green=green>>2;				//shift down to 6-bits
		blue=blue>>3;				//shift down to 5-bits
		RGB16[i]= (RGB16[i] | red);		//put red 5-bits into int
		RGB16[i]= (RGB16[i] << 6);		//move red bits over, make room for green
		RGB16[i]= (RGB16[i] | green);		//put green 6-bits into int
		RGB16[i]= (RGB16[i] << 5);		//move red and green bits over, make room for blue
		RGB16[i]= (RGB16[i] | blue);		//put blue 5-bits into int
	for(i=0;i<25600;i++){
			GPIO_Write(GPIOB, (RGB16[i]));
TFT_24S_Write_Command(0x0029);				//display ON
result = f_close(&File1);				// close file
	if (result != FR_OK) {
		UILCD_SetCursor(0,0);UILCD_DisplayString("File not Closed ");while(1);
		return result;}
UILCD_SetCursor(0,0);UILCD_DisplayString("Press SEL button");UILCD_SetCursor(1,0);UILCD_DisplayString("for next file.  ");
while(GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_2)!=0){;}
image++;
if(image==0x3A){image=0x41;}
filename[13]='\0';
	{image=0x30;}
filename[13]='\0';
return 1;
* Function Name  : TFT_24_9340_Init
* Description    : Initializes LCD with built-in ILI9340 controller.
* Input          : None
* Output         : None
* Return         : None
void TFT_24_9340_Init(void)
GPIO_WriteBit(GPIOC, RES, Bit_RESET);
TFT_delay(100);
GPIO_WriteBit(GPIOC, RES, Bit_SET);
TFT_delay(100);
TFT_24S_Write_Command(0x0028);//display OFF
TFT_24S_Write_Command(0x0011);TFT_24S_Write_Data(0x0000);				//exit SLEEP mode
TFT_24S_Write_Command(0x00C0);TFT_24S_Write_Data(0x0026);TFT_24S_Write_Data(0x0004);	//power control 1
TFT_24S_Write_Command(0x00C1);TFT_24S_Write_Data(0x0004);				//power control 2
TFT_24S_Write_Command(0x00C5);TFT_24S_Write_Data(0x0034);TFT_24S_Write_Data(0x0040);	//VCOM control 1
TFT_24S_Write_Command(0x0036);TFT_24S_Write_Data(0x0088);				//memory access control = BGR
TFT_24S_Write_Command(0x00B1);TFT_24S_Write_Data(0x0000);TFT_24S_Write_Data(0x0018);	//frame rate control
TFT_24S_Write_Command(0x00B6);TFT_24S_Write_Data(0x000A);TFT_24S_Write_Data(0x00A2);	//display function control
TFT_24S_Write_Command(0x00C7);TFT_24S_Write_Data(0x00C0);				//VCOM control 2
TFT_24S_Write_Command(0x003A);TFT_24S_Write_Data(0x0055);				//pixel format = 16 bit per pixel
TFT_24S_Write_Command(0x00E0);TFT_24S_Write_Data(0x001F);				//positive gamma correction
				TFT_24S_Write_Data(0x001B);
				TFT_24S_Write_Data(0x000B);
				TFT_24S_Write_Data(0x000F);
				TFT_24S_Write_Data(0x0009);
				TFT_24S_Write_Data(0x0046);
				TFT_24S_Write_Data(0x00B5);
				TFT_24S_Write_Data(0x0037);
				TFT_24S_Write_Data(0x000C);
				TFT_24S_Write_Data(0x0007);
				TFT_24S_Write_Data(0x0005);
TFT_24S_Write_Command(0x00E1);TFT_24S_Write_Data(0x0000);				//negative gamma correction
				TFT_24S_Write_Data(0x0024);
				TFT_24S_Write_Data(0x0027);
				TFT_24S_Write_Data(0x0010);
				TFT_24S_Write_Data(0x0006);
				TFT_24S_Write_Data(0x0039);
				TFT_24S_Write_Data(0x0074);
				TFT_24S_Write_Data(0x0048);
				TFT_24S_Write_Data(0x0013);
				TFT_24S_Write_Data(0x0038);
				TFT_24S_Write_Data(0x003A);
TFT_24S_Write_Command(0x002A);TFT_24S_Write_Data(0x0000);				//column address set
               			TFT_24S_Write_Data(0x0000);				//start 0x0000
				TFT_24S_Write_Data(0x00EF);				//end 0x00EF
TFT_24S_Write_Command(0x002B);TFT_24S_Write_Data(0x0000);				//page address set
				TFT_24S_Write_Data(0x0001);
				TFT_24S_Write_Data(0x003F);				//end 0x013F
The example code you have posted is incomplete and presented as a small series of routines.
Most likely the code was initially written for a microcontroller architecture which utilizes a set of registers to define direction, clear and set various port pins.
GPIO_ResetBits(PORT, PIN) - clears the GPIO PIN of PORT
GPIO_SetBits(PORT, PIN) - sets the GPIO PIN of PORT
etc..
Simply develop similar routines for manipulating GPIO pins for the AVR architecture.
BigDog
