tran
Member level 4
Hi all,
I begin study network, and I meet some difficulties. I see in some document people say that they can tranfer differential signal, but I don't understand what is called differential signal. If we tranfer differential signal, we use two line , one for + and one for -, example we use "RxD+" & "RxD-" to tranfer 'receive data'. But I don't understand : What is differential signal?
Does differential signal mean that the voltage between pin "RxD+" to "Ground" and voltage between pin "RxD-" to "Ground" and we need a different pair circuit at receiver to receive this signal, we must connect signal "Ground" (that we tranfer from transmitted station) to ground node of our circuit and "RxD+" &"RxD-" to the inputs of our circuit ? or Does differential signal mean that voltage between "RxD+" and "RxD-" and at the receiver we only connect "RxD+" and "RxD-" to the inputs of our different pair, do not connect "Ground" to ground node of our circuit, the signal "Ground" dose not use? in this situation.
Can anybody give me some ideal about this problem?
Thank you very much.
