what is compact antenna test range
mayavi
Junior Member level 3
ind
hi,
could anybody tell and send some details on compact antenna test range?
In a compact range, a reflector antenna it use to create the "plane waves" within a short distance.
Compact ranges work fine, and are especially useful inside of a building. But they are not trivial to set up. Hacking away at some kluge will probably not work. Expect to spend tens of thousands of $.
