what is capacitive loads ?
vvsvv
Full Member level 1
what is inductive loads ?
what is resistor loads ?
Thanks.
vijayanand_ME
Member level 1
There is no pure inductive load and capacitive loads practically (small resistance will be there)
Inductive loads are the one whose inductance is high compare to its Resistance.
For example induction motors, or a simple coil.
Capcitive loads are the one whose capacitance is high compare to its Resistance.
for Example PF correction capacitors, synchronous motors or simply a bulk capaciators;
We catagories these on the power factor also.
inductive : Its lagging PF
Capacitive : Its Leading PF
Resistive : Its Unity PF
hope it helps.
-VJ
vvsvv
Full Member level 1
Thanks abaidullah,vijayanand_ME
Thank you very much.
The info is very helpful !!
saas123qa
Member level 2
the resistve load is a pure resistance load such as resistor, whreras inductive load such as ideal coils , and capacitve load is like ideal capacitors ( the difference between capactive and inductive load one makes the current lead the voltage and the other is the opposite)
