[SOLVED] what is basic executabale format in ubuntu linux?
blooz
Advanced Member level 2
India
what type of file is the basic executable format in ubuntu linux?
As every Unix-like OS, Linux has ELF (Executable and Linkable Format) see Wikipedia or at a shell type: "man elf" or "info elf".
Reactions: blooz
    blooz
There are several types of "executable format" Linux can support
The oldest is "a.out" (this is long beard and sandal Unix format)
If the program is not self contained (ie it needs library code) then the normal format is ELF.
However Linux will also load and run self contained image files (it has to otherwise it could never get going to get the library files) and many lightweight "embeded" systems do this if they only run a single main application (such as digital osciloscope or ECG machine or Advertising hording/wall).
For most users they don't care as it is the Linux Loder prog 'ld' that does the heavy lift,
ld-linux(8): dynamic linker/loader - Linux man page
Reactions: blooz
    blooz
