cupoftea
Advanced Member level 5
Can you advise what exactly is a “Transformer Rectifier Unit”? (TRU) Google doesn’t help much.
1...Does it always involve an iron transformer rather than ferrite?
2...Does it usually operate at around 50-60Hz? (ie not 50khz plus)?
3...Is the “rectifier” usually a thyristor based rectifier? If so is it leading or trailing edge fired?
4...What is the power factor of a TRU like?
5...What sort of loads do they supply?
6...Is it usually used in 3 phase systems? (is it only used in 3 phase systems?)
7...Is it for use where ferrite based SMPS’s simply cant handle the power levels?
8...Is the switching frequency of the “rectifiers” always less than 1khz? (and most often around 100-120Hz?)
9...Presumably the supply for the rails of the London Underground trains come from a TRU?
10...Do any EV chargers use TRU’s?
11...What power level is it where a TRU must be used?
12...Most SMPS (eg full bridge) have a “transformer and a rectifier”, so why are they not called a “TRU”?
13...Do they usually use big capacitor banks to smooth the output?...or is the output usually inductive?
14...Does a TRU ever use IGBTs?
