What is a data path block in frontend ?
S.Nikhil
what is a data path block in frontend
data path block
ADDER should be one of them.
Re: data path block
Almost every design can be partitioned into 2 funtional parts.
1). Datapath blocks such as collection of the following: adder, multiplier, muxes, and all arithmatic/logic operations
2). Control block, which sends control signal to datapath to operate.
For Example: if you see page Number 48 in
http://www.vlsiip.com/video/MscPrj.pdf
you can clearly see the design partitioned into datapath/control
Hope it helps,
Kr,
Avi
Re: data path block
Hi Avi,
Nice project. I always want to learn some knoledge of video compression,but did not find time and how to cut in. I will go over your project to see if I could understand some points of Video. That will be great if you could give some suggestions on how to get into video field. More practical stuff not theory.
Hope it helps,
Kr,
Avi
    S.Nikhil
