aliumair926
Junior Member level 3
Hi, my name is Umair , I m doing my project related to SDR. It is making an PC based FM receiver using soundcard as ADC. I am in my initial days of project. The problem that i am coming across is the RF part. What hardware should i use to get the required signal for signal processing. If i use downconverter wht would be the complete procedure..Kindly give your valuable suggestions...Thanks in advance
