ep.hobbyiest
Full Member level 4
- Joined
- Jul 24, 2014
- Messages
- 212
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 18
- Activity points
- 1,487
i am using mplab x ide, xc8 compiler and pic16f1516 controller.
while doing programming i got some error as follows. which are not related to programming and never related to file inclusion.
And error as follows:
if i click on follow error
then nothing happen and other page get opened as follows
so what is solution on that
:: warning: (1273) Omniscient Code Generation not available in Free mode
:0: error: (500) undefined symbols:
_key_code(dist/default/production\sa.X.production.obj) _dcount(dist/default/production\sa.X.production.obj) _key_ready(dist/default/production\sa.X.production.obj) _scan_no(dist/default/production\sa.X.production.obj) _krcount(dist/default/production\sa.X.production.obj)
nbproject/Makefile-default.mk:135: recipe for target 'dist/default/production/sa.X.production.hex' failed
make[2]: Leaving directory 'C:/Users/SAAG/MPLABXProjects/sa.X'
nbproject/Makefile-default.mk:78: recipe for target '.build-conf' failed
make[1]: Leaving directory 'C:/Users/SAAG/MPLABXProjects/sa.X'
nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
(908) exit status = 1
make[2]: *** [dist/default/production/sa.X.production.hex] Error 1
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
BUILD FAILED (exit value 2, total time: 11s)
# Generated Makefile - do not edit!
# Edit the Makefile in the project folder instead (../Makefile). Each target
# has a -pre and a -post target defined where you can add customized code.
# This makefile implements configuration specific macros and targets.
# Include project Makefile
ifeq "${IGNORE_LOCAL}" "TRUE"
# do not include local makefile. User is passing all local related variables already
else
include Makefile
# Include makefile containing local settings
ifeq "$(wildcard nbproject/Makefile-local-default.mk)" "nbproject/Makefile-local-default.mk"
include nbproject/Makefile-local-default.mk
endif
endif
# Environment
MKDIR=gnumkdir -p
RM=rm -f
MV=mv
CP=cp
# Macros
CND_CONF=default
ifeq ($(TYPE_IMAGE), DEBUG_RUN)
IMAGE_TYPE=debug
OUTPUT_SUFFIX=elf
DEBUGGABLE_SUFFIX=elf
FINAL_IMAGE=dist/${CND_CONF}/${IMAGE_TYPE}/sa.X.${IMAGE_TYPE}.${OUTPUT_SUFFIX}
else
IMAGE_TYPE=production
OUTPUT_SUFFIX=hex
endif
# Object Directory
OBJECTDIR=build/${CND_CONF}/${IMAGE_TYPE}
# Distribution Directory
DISTDIR=dist/${CND_CONF}/${IMAGE_TYPE}
# Source Files Quoted if spaced
SOURCEFILES_QUOTED_IF_SPACED=main.c lcd.c
# Object Files Quoted if spaced
OBJECTFILES_QUOTED_IF_SPACED=${OBJECTDIR}/main.p1 ${OBJECTDIR}/lcd.p1
POSSIBLE_DEPFILES=${OBJECTDIR}/main.p1.d ${OBJECTDIR}/lcd.p1.d
# Object Files
OBJECTFILES=${OBJECTDIR}/main.p1 ${OBJECTDIR}/lcd.p1
# Source Files
SOURCEFILES=main.c lcd.c
CFLAGS=
ASFLAGS=
LDLIBSOPTIONS=
############# Tool locations ##########################################
# If you copy a project from one host to another, the path where the #
# compiler is installed may be different. #
# If you open this project with MPLAB X in the new host, this #
# makefile will be regenerated and the paths will be corrected. #
# fixDeps replaces a bunch of sed/cat/printf statements that slow down the build
FIXDEPS=fixDeps
.build-conf: ${BUILD_SUBPROJECTS}
ifneq ($(INFORMATION_MESSAGE), )
@echo $(INFORMATION_MESSAGE)
endif
${MAKE} -f nbproject/Makefile-default.mk dist/${CND_CONF}/${IMAGE_TYPE}/sa.X.${IMAGE_TYPE}.${OUTPUT_SUFFIX}
MP_PROCESSOR_OPTION=16F1517
# Rules for buildStep: compile
${OBJECTDIR}/main.p1: main.c nbproject/Makefile-${CND_CONF}.mk
@${MKDIR} ${OBJECTDIR}
@${RM} ${OBJECTDIR}/main.p1.d
${MP_CC} --pass1 $(MP_EXTRA_CC_PRE) --chip=$(MP_PROCESSOR_OPTION) -Q -G -D__DEBUG=1 --debugger=pickit2 --double=24 --float=24 --opt=default,+asm,+asmfile,-speed,+space,-debug --addrqual=ignore --mode=free -P -N255 --warn=0 --asmlist --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,+osccal,-resetbits,-download,-stackcall,+clib --output=-mcof,+elf:multilocs --stack=compiled:auto:auto "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" -o${OBJECTDIR}/main.p1 main.c
@-${MV} ${OBJECTDIR}/main.d ${OBJECTDIR}/main.p1.d
@${FIXDEPS} ${OBJECTDIR}/main.p1.d $(SILENT) -rsi ${MP_CC_DIR}../
${OBJECTDIR}/lcd.p1: lcd.c nbproject/Makefile-${CND_CONF}.mk
@${RM} ${OBJECTDIR}/lcd.p1.d
${MP_CC} --pass1 $(MP_EXTRA_CC_PRE) --chip=$(MP_PROCESSOR_OPTION) -Q -G -D__DEBUG=1 --debugger=pickit2 --double=24 --float=24 --opt=default,+asm,+asmfile,-speed,+space,-debug --addrqual=ignore --mode=free -P -N255 --warn=0 --asmlist --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,+osccal,-resetbits,-download,-stackcall,+clib --output=-mcof,+elf:multilocs --stack=compiled:auto:auto "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" -o${OBJECTDIR}/lcd.p1 lcd.c
@-${MV} ${OBJECTDIR}/lcd.d ${OBJECTDIR}/lcd.p1.d
@${FIXDEPS} ${OBJECTDIR}/lcd.p1.d $(SILENT) -rsi ${MP_CC_DIR}../
else
${MP_CC} --pass1 $(MP_EXTRA_CC_PRE) --chip=$(MP_PROCESSOR_OPTION) -Q -G --double=24 --float=24 --opt=default,+asm,+asmfile,-speed,+space,-debug --addrqual=ignore --mode=free -P -N255 --warn=0 --asmlist --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,+osccal,-resetbits,-download,-stackcall,+clib --output=-mcof,+elf:multilocs --stack=compiled:auto:auto "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" -o${OBJECTDIR}/main.p1 main.c
${MP_CC} --pass1 $(MP_EXTRA_CC_PRE) --chip=$(MP_PROCESSOR_OPTION) -Q -G --double=24 --float=24 --opt=default,+asm,+asmfile,-speed,+space,-debug --addrqual=ignore --mode=free -P -N255 --warn=0 --asmlist --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,+osccal,-resetbits,-download,-stackcall,+clib --output=-mcof,+elf:multilocs --stack=compiled:auto:auto "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" -o${OBJECTDIR}/lcd.p1 lcd.c
endif
# Rules for buildStep: assemble
else
endif
# Rules for buildStep: link
dist/${CND_CONF}/${IMAGE_TYPE}/sa.X.${IMAGE_TYPE}.${OUTPUT_SUFFIX}: ${OBJECTFILES} nbproject/Makefile-${CND_CONF}.mk
@${MKDIR} dist/${CND_CONF}/${IMAGE_TYPE}
${MP_CC} $(MP_EXTRA_LD_PRE) --chip=$(MP_PROCESSOR_OPTION) -G -mdist/${CND_CONF}/${IMAGE_TYPE}/sa.X.${IMAGE_TYPE}.map -D__DEBUG=1 --debugger=pickit2 --double=24 --float=24 --opt=default,+asm,+asmfile,-speed,+space,-debug --addrqual=ignore --mode=free -P -N255 --warn=0 --asmlist --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,+osccal,-resetbits,-download,-stackcall,+clib --output=-mcof,+elf:multilocs --stack=compiled:auto:auto "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" -odist/${CND_CONF}/${IMAGE_TYPE}/sa.X.${IMAGE_TYPE}.${DEBUGGABLE_SUFFIX} ${OBJECTFILES_QUOTED_IF_SPACED}
@${RM} dist/${CND_CONF}/${IMAGE_TYPE}/sa.X.${IMAGE_TYPE}.hex
else
${MP_CC} $(MP_EXTRA_LD_PRE) --chip=$(MP_PROCESSOR_OPTION) -G -mdist/${CND_CONF}/${IMAGE_TYPE}/sa.X.${IMAGE_TYPE}.map --double=24 --float=24 --opt=default,+asm,+asmfile,-speed,+space,-debug --addrqual=ignore --mode=free -P -N255 --warn=0 --asmlist --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,+osccal,-resetbits,-download,-stackcall,+clib --output=-mcof,+elf:multilocs --stack=compiled:auto:auto "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" -odist/${CND_CONF}/${IMAGE_TYPE}/sa.X.${IMAGE_TYPE}.${DEBUGGABLE_SUFFIX} ${OBJECTFILES_QUOTED_IF_SPACED}
endif
# Subprojects
.build-subprojects:
# Subprojects
.clean-subprojects:
# Clean Targets
.clean-conf: ${CLEAN_SUBPROJECTS}
${RM} -r build/default
${RM} -r dist/default
# Enable dependency checking
.dep.inc: .depcheck-impl
DEPFILES=$(shell mplabwildcard ${POSSIBLE_DEPFILES})
ifneq (${DEPFILES},)
include ${DEPFILES}
endif
