wolfrain
Junior Member level 1
- Joined
- Nov 14, 2009
- Messages
- 19
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,283
- Location
- Southampton
- Activity points
- 1,454
Hello guys.
I am a little bit confused with this concept - 'DC Transfer Characteristic'. In fact, I am doing a simple two-stage Op Amp, and up to now all the sizes has been figured out and put them into LTSpice and simulated it.
But I have a specification called Output Voltage Range, which requires at least +- 0.8V with respect to ground while maintaining the specified gain. In addition, I have been provided with a test circuit for this spec where I have to connect the negative terminal of the Op Amp to ground and a DC source (sweep from -10mV to 10mV) to positive terminal.
Here I attached the output waveform. This jpeg shows the systematic offset. But I don't get it. Why do I need to use this configuration to measure the output in this way? What is it for? Does it mean, like if the slope keeps linear between -0.8V to +0.8V, then I can have a good Op Amp? What does it mean? And why do I need to sweep the DC source in this way? What is the DC Transfer for?
Thank you guys, I will be really appreciated for your helps here.
