What does "hot-socketing support" mean?
cdcll
Full Member level 3
Full Member level 3
hot socketing
Hi all,
The doc of Altera CPLD MAX3000A said the devide support hot-socketing, does it mean the device is hot pluggable?
Best Regards,
cdcll
hot socketing
Hot soketing refers to the way a plug can be connected with the power on . So if your deviuce is hot plugable you cad safely connect it to its circuit with the power applide
Barrybear
hot-socketing
Has some one tried this features?
hot socketing latchup
Does anyone know if the Xilinx CPLD 95xxXL support hot-socketing or not?
support mean
Hot socketting means that chip have very good latchup protection. It means that every chip pin can survive large (100mA and more) latchup currents.
I didn't find any hot socket declaration for Xilinx devices but they declare latchup currents 300mA for FPGA devices and 200mA for EPLD devices.
Another problem with hot socketting is what will happen with power-on reset, register states and configuration SRAM after plugging. I think that you can fast plug device but after that you need to manual reset device or switch on/off power. So in this case hot socketting is not so significant advantage.
Regards
Re: hot socketing
cdcll said:
Hi all,
Best Regards,
cdcll
“Cyclone® II devices offer hot socketing (also known as hot plug-in, hot
insertion, or hot swap) and power sequencing support without the use of
any external devices. You can insert or remove a Cyclone II board in a
system during system operation without causing undesirable effects to
the board or to the running system bus.”
This article is found on the ALTERA'S Cyclone II Device Handbook.
I think it can answer your question.
