What does ADDR[A|B] mean?
cloudz88
Member level 1
Member level 1
ADDR[A|B]<m:0>
i dun realli understand the <m:0>
its from dual port ram...>_<''
wat does this means?
Where did you see that? Can you show us the whole paragraph?
Re: wat does this means?
If it's from the documentation for the Xilinx memory cores, it is a shorthand way of referring to ports ADDRA[m:0] or ADDRB[m:0].
It gives a variable for the upper index of the bus because that is, of course, configurable by you. ADDRA could be 2 bits wide (m = 1, or [1:0]) or it could be 64 bits wide (m=63, or [63:0])
You probably saw this on a table in the core documentation that has the typical port list for your selected core.
r.b.
