What dimensions should I change to increase bandwidth in rectangular patch antenna?
kh_mob
Newbie level 3
hi, can anyone tell me what is the dimensions i have to change in rectangular patch antenna to increase Bandwidth without changing the operating frequency??
Re: help, patch antenna
Hi, kh_mob:
The simplist and very effective way is to increase the substrate thickness. If the substrate thickness is fixed, you can make the patch wider or bigger dimension in the non-resonating side. Regards.
I have this pdf's try it
