other than that it'll be the values of the components you have picked.
don't apply an input frequency, and look at the output of the VCO to see what frequency it is sitting at. Chenge some external components untill the VSO rests at the frequency you require it to be at.
Could you specify what kind of PLL you use?
Where does this PLL come from? In-house design or external IP??
If possible, plz specify what kind of waveform you observe during characterization??
The lock range may be too low to tolerate 50 instead of 54.1 MHz. Normally I would expect an IP core to be parametrizable for different reference clocks, if technical possible. But you could use a test generator with variable frequency to see if the PLL locks at all.
