When using a rectifier diode, the parameters such as maximum rectification current, maximum reverse operating current, cutoff frequency, and reverse recovery time should be considered.I wonder whether there is something that can replace rectifier diode after the rectifier diode is damaged?
You know the part number of the rectifier diode. Look into its data sheet. Find another rectifier diode with similar characteristics or buy the same diode using the part number information.
