What are the specifications for opamp in voltage regulator?
bouchy
Full Member level 1
USA
Hi All,
what are the spec for op amp in voltage regulator? I am talking about using op amp and pass transistor.
Thanks a lot.
IanP
Advanced Member level 7
West Coast
Re: Voltage regulator
In this application virtually any Opamp (even a pair of 2 discrete BJTs in differential configuration) will perform well ..
Just make sure that the max rated supply voltage is higher than the highest expected unregulated input voltage ..
That’s all ..
Regards,
IanP
    bouchy
