First you must understand, what are the benefits of SSB compared to DSB. It uses less bandwidth and etc. There are two methods for SSB, LSB(Lower SB) and USB(Upper SB).. Which one to use LSB or USB? Well, it depends on the application you are using on. You should read up more on Amplitude Modulation.. Hope this explanation helps..
