What are the differences between p and n type mosfets?
zhi_yi
Full Member level 4
Full Member level 4
hi there, is there any good tutorials to learn about mosfets? mosfet are divided into p type mosfet and n type mosfet? what is the differences between p and n type mosfet with the depletion type and enhancement type mosfet?
thank you
n type mosfet
Some one acutally started a post regarding mosfet on the analog circuits board:
A lot of useful information posted there.
It would be really good if you read this first:
https://en.wikipedia.org/wiki/Mosfet
To answer your question,
n type mosfet, which is usually called nmos,
lies on a P type substrate. When its turned on,
the conducting channel if formed by an inversion layer of electrons, which connects 2 n-type places.
p type mosfet, is called pmos. It lies on N type substrate. When its turned on, the conducting channel is formed by "holes". and it connects 2 p-type places.
The depletion region is formed between the n and p type. https://en.wikipedia.org/wiki/Depletion_region
Hope that helps.
difference between n-type and p-type mosfet
the following doc gives basic understanding.
u get lot of info on net search google.
n-type mosfet
n-mosfet is most frequently used than p mosfet since former is having high mobility which leads to several advantages
p-mosfet wiki
Pmos as name indicates uses holes as carries for operation and we need to apply -ve voltage so that holes will attract and form a layer for conduction..so its Vt is -ve..........for NMOS we will apply +ve volt and carriers are electrons...
mosfet wiki
the book microelectronics by sedra and smith gives and excellent comparative analysis between these devices..
you'll develop a hight level of clarity if you go through that..
regards,
wiztronix
difference between n-type and p-type mosfets
you may consult following book
electronics devices and circuit theory
by
bolysted...
In chapter 6...u will find very easy to understand text on FET's..
hope that answers the question
p mosfet wiki
p typr mosfets have n channel and n ype have p channel in them
basic diff is the applied voltage levels.
i suggest u to better consult electronic devices and circuit theory by bolysted.
ch 6
u will find answer to all yr questions
regards
ali
difference between n mosfet and p mosfet
Not always... In diff-amp circuits, if there is no headroom wrt the available VDD, most of the time it'll be pmos which'll used as input transistors. You can add to it the current mirror circuitry... there you are, more pmos than nmos... :D
Of course, I agree with you in that pmos devices are inherently slower than the nmos counterparts..
