What are the costs of using blind vias on PCB?
maxascent
Member level 2
Member level 2
England
Hi
Does anyone have any idea of the cost of using blind vias on a pcb?
cheers
Jon
Re: PCB Costs
blind vias will cost more, for testing board, we use PCB without blind vias , because of our circuit is simple, no much signal and easy to layout PCB!just for info
Re: PCB Costs
check with fabricators. It depends on the stackup you are using.
Compare with multi layer board, this will be quite expensive. And also lead time will be longer than normal multi layer boards.
