Re: ADv of Open Drain ckt
Open drain is one of the many different electrical input/output standards in digital designs today.
[edit]
Definition of Open-Drain
Open-drain refers to the drain terminal of a MOSFET transistor. (The analog for BJT devices is the open collector.) An open drain terminal is connected to ground in the low voltage (logic 0) state, but has high impedance in the logic 1 state. This prohibits current flow, but as a result, such a device requires an external pull-up resistor which is also connected to the positive voltage rail.
When a device is in the high-impedance state, the pull-up resistor keeps the line at logic 1. The line stays there until the device goes into the logic 0 state, and begins to sink current. This current flow creates a voltage drop across the pull-up resistor, and the line drops to the logic 0 voltage.
[edit]
Applications of Open-Drain Devices
One useful property is that the resistor need not be connected to the same voltage as the chip supply voltage Vcc: a lower or higher voltage can be used instead. Open drain circuits are therefore sometimes used to interface two series of devices that have different operating logic levels (voltages.)
Another advantage is that more than one open-drain output can be attached to a single wire. If all outputs attached to the wire are in the high-impedance/logic 1 state, the pull-up resistor will hold the wire in a high voltage state. If at least one of the device outputs is in the ground/logic 0 state, it will sink current and bring the line voltage low. This is analogous to a logical-AND function.
One common use of Open Drain pin is that it enables the device to provide system-level control signals (that is, interrupt and write-enable signals) that can be asserted by several outside devices.
