What are tap cells ?
deh_fuhrer
Full Member level 5
What are Tap Cells.Could somebody please explain the use of tap cells.
tap cells for latch up
tapping is done to avoid latch up effect......hope u know latch up effect...
so for that n tap is connected to p transistor....by connecting p tap over VDD
similarly for p tap ....is connected to n transistor....connected to VSS...
hope this helps,
Prasad
Tap Cells
I guess you can also say that well taps are placed in order to ensure the substrate/well is kept at vdd/gnd potential or very close to it. Switching circuits dump current into well/substrate and if there is a high resistance between substra/well and the vdd/gnd grids the substrate can be at different potential than vdd/gnd (this cause potential latchup and all sorts of other effects). More taps reduces the resistance.
