What’s the difference between current-transformer and voltag
ZengLei
Full Member level 1
WuHan China PR
I found that the CT could make the voltage in secondary higher than primary ,so is the CT can be seen as a voltage-transformer????
What’s the difference between current-transformer and voltage-transformer??????
Thanks~~~~~
A.Anand Srinivasan
Advanced Member level 5
India
Re: What’s the difference between current-transformer and vo
i think a current transformer gives a voltage proportional to the current in the primary.. for voltage transformer it gives voltage proportional to voltage in primary...
ranganath_d
Member level 1
Transformer is a device where energy neither created nor destroyed. in this way CT is the one which is a step up or step down current while holding same energy at input as well as output. same statement applies to voltage transformer...
Kral
USA
ZengLei,
There is no fundamental difference between the two. Typically a current transformer will have a primary with a small number of turns of large diamter wire, to minimize the voltage drop across the primary. This is because you want to be able to measure current (by inserting the primary in series with the circuit to be measured) without altering the current that existed without the current transformer. The current transformer also typically has a high turns ratio. The load resistance that is reflected back to the primary is equal to the (fixed) load resistance connected to the secondary divided by the square of the turns ratio. The lower the reflected resistance is, the smaller the voltage drop across the primary will be.
Regards,
Kral
    ZengLei
A.Anand Srinivasan
India
ya current transformer can be used as voltage transformer too.... but the main thing is they are optimised for different purposes...
    ZengLei
ZengLei
Full Member level 1
WuHan China PR
Thanks all~~~~~~
and what's the crucial parameter i must note when i use a CT,THANKS~~~~~
