Weird interrupt problem pic16f690
Lipton2
Hello guys!
I have been struggeling with this problem for hours now and i can't seem to get it fixed.
Maybe it is just is simple mistake, but i hope you can help me.
I am trying to make a simple interrupt with a PIC16F690 that blinks a LED every second.
As you can see i first declared all the INTCON en OPTION registers that were needed.
And since i have a default internal oscillator of 4Mhz I used a Fosc of 1 Mhz to calculate the count of overflows.
But when i program my device, instead of 1, all four LED's are on and they are not blinking.
What is wrong?
I hope you can help me!
Thanks in advance!
Oh btw, I use the XC8 compiler
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
#include <htc.h>
#include <pic16f690.h>
    unsigned char counter=0;//Overflow counter
    //void interrupt ISR(void);
    void main()
       //Setup Timer0
       OPTION_REGbits.PS0=1; //Prescaler is divide by 256
       OPTION_REGbits.PS1=1;
       OPTION_REGbits.PSA=0;      //Timer Clock Source is from Prescaler
       OPTION_REGbits.T0CS=0;     //Prescaler gets clock from FCPU (1MHz)
       INTCONbits.T0IE=1;   //Enable TIMER0 Interrupt
       INTCONbits.T0IF=0;
       INTCONbits.PEIE=1;     //Enable Peripheral Interrupt
       INTCONbits.GIE=1;      //Enable INTs globally
       TRISC=0;
      while(1)
    //Main Interrupt Service Routine (ISR)
    void interrupt ISR ()
       //Check if it is TMR0 Overflow ISR
       if(INTCONbits.T0IE && INTCONbits.T0IF)
           counter ++;
           if (counter == 15)
         PORTCbits.RC0;
         counter = 0;
         INTCONbits.T0IF=0;
Thanks for your reply!
When I implement this in my code, all four LED´s (RC0-RC3) are on, but after a second or so, three (RC1-RC3) LED's turn off again. Isn't that very weird since I only gave an action to RC0? It seems like the program only goes through the interrupt once and then gets stuck in the main loop. How can I fix this?
Thanks!
Yes whatchdog timer was disabled, but i already fixed the problem I think!
I added an else statement to the if statement with the counter.
The LED now blinks every second!
Thanks for your help!
       if(INTCONbits.T0IF==1)
           counter ++;
           if (counter == 15)
                PORTC=0b00000001;
                counter = 0;
           else PORTC =0;
         INTCONbits.T0IF=0;
