Weird gm/id vs vgs result in Cadence
kidmanbasha
Member level 1
gm / vgs
I am trying to simulate gm/id vs vgs in cadence but I get a strange transition when vgs approaches zero as shown below.
How I did the simulation : sweep vgs vs id then using the calculator i get the derivative of id and divide by id to get gm/id
id vs vgs
It's not weird, it's normal: in sub-threshold (= weak-inversion) you have maximum gm/id , s. e.g. E. Vittoz' weak-inversion paper below (p. 10).
vgs vs id
you can also use dc analysis and obtain 'gmoverid' parameter.
ids vs vgs cadence
erikl...I did as oermens said and the result is as expected without the the sudden peaking at vgs--->0.
id versus vgs
So the SPICE DC calculations provide a smoother transition from weak <-> strong inversion!?
yes. actually the peaking was in the inversion region only cuz the vto of my process (0.13u) is between 0.2 and 0.3
