web sever in fpga ....
didier
fpga web server
....the project is to access image from from the fpga by access from any terminal that have internet connection.....the fpga will have tcpip,ethernet,.......can the project complete.....any suggestion...
fpga http server
Hello didier,
For running a Web-Server on a FPGA there are some possibilities. For example you can use a soft-processor like Nios from Altera or MicroBlaze from Xilinx. You can write a simple web-server by your own or use ready made operating systems with the soft-cores (e.g. embedded Linux).
Is there a special reason that you would like to use an FPGA? If you only need an embedded web-server there are other cheaper solutions on the market.
Regards,
cube007
Here you are. A complete webserver implemented on Xilinx EDK; processor based.
Regards,
Amr.
    didier
do you have web server in NIOS altera fpga?
Hello didier,
Yes you can run a web server on Nios II too. Take a look at the following web sites:
https://www.altera.com/products/ip/processors/nios2/ni2-index.html
https://www.altera.com/products/ip/processors/nios2/kits/ni2-dev_kits.html
If you would like to get in touch the easiest way is to buy a development kit.
Regards.
cube007
actually my project is to access image from the altera Nios developement kits from any internet connection point , if i use chipset it not cool .....so i have to design my own IP and ethernet soft-ware in the fpga...
