Register Log in
Water absorption simulations
threecat2
Newbie level 3
I am curious whether IE3D (hyperlynx) can simulate material absorption rates for water and such, and whether it can track how the antenna load changes according to surrounding lossy objects. Any help?
Thanks.
rodgerwxh
Banned
North Carolina
Is there any special requirement for this case that will challenge the popular simulator like HFSS, CST, IE3D? It is a radiator surrounded by materials and calculate its input impedance, am I right?
threecat2
Newbie level 3
Yes, that's exactly what I want to do. I was just wondering if IE3D provides any 'layers' such as water at a certain temperature in its simulation environment.
WimRFP
Advanced Member level 5
Netherlands
For insulators you mostly specify real part and imaginary part of relative epsilon (e' and e"), or a single value for epsilon and a loss factor (tan(delta)).
As water contains contaminants you need to know the conductivity. Pure water has very low conductivity and therefore "relative" low loss (as only eps.r of about 80 dominates). Just traces of contaminants will increase the conductivity, hence the loss.
What is your frequency and are you simulating in pure, fresh or sea water?
If you want to measure conductivity of own samples, don't use your Ohm meter. You can't reliably measure conductivity with a 2 wire interface and DC (so you need an AC source).
Toggle Sidebar
