i'm now implementing a differential amplifer by using AD620. the output of the Ad620 was not equal to zero while the input is null. so i added in a ua741 to null the output.
i was wish to use another type of op-amp beside ua741,wat should i use?in order to get better performance. i wan to make my experiment result more various with differet type of op-amp.
There is planty to choose from ..
For example:
MC3371
LF351
TL061
TL071
OP42
TL081
to name just a few ..
All the above opamps are pin-to-pin compatibile with the LM741 ..
thx very much o...i'm a very junior in engineering field. so i will ask something very basic which might be very funny.....thx for replying...help me lots....
to be sure, you can find the datasheets on the internet by google juste write the name of your device and what you are cherching for (datasheet).
It is very easy to compare
look at an lf411, good general purpose op-amp with great temperature stability. The guy who wrote Art of Electronics uses it as his 'jelly-bean' amp and does so for a reason. They cost more than a 741 though.
