kcinimod
Member level 3
Hi, can someone explain to me what the warnings mean for the below code ?
Thanks.
Thanks.
library ieee;
use ieee.std_logic_1164.all;
entity counter is
port(
clk : in std_logic;
data : in std_logic;
enable : in std_logic;
compare_reset : in std_logic;
dout : out std_logic
end counter;
architecture count of counter is
signal data_sync : std_logic_vector(1 downto 0);
signal pre_count : integer;
signal pre_count_1 : integer;
signal pre_count_2 : integer;
signal data_count : integer;
signal dout_count : std_logic;
begin
process(clk)
begin
if rising_edge(clk) then
data_sync <= data_sync(0) & data;
elsif falling_edge(clk) then
data_sync(1) <= '0';
end if;
end process;
count_proc : process(clk, enable, data_sync)
begin
if (enable = '0') then
data_count <= 0;
pre_count <= 0;
pre_count_1 <= 0;
pre_count_2 <= 0;
elsif (data_sync(1) = '1') then
pre_count <= 0;
elsif rising_edge(clk) then
pre_count <= pre_count + 1;
end if;
if (data_count = 0) then
pre_count <= 0;
data_count <= data_count + 1;
elsif (data_count = 1) then
pre_count_1 <= pre_count;
elsif (data_count = 2) then
pre_count_2 <= pre_count;
data_count <= data_count - 1;
end if;
end if;
end process;
compare_proc : process(pre_count_1, pre_count_2, compare_reset)
begin
if (compare_reset = '0') then
dout_count <= '0';
elsif (pre_count_2 /= 0 and dout_count = '0') then
if (pre_count_1 > pre_count_2) then
dout <= '1';
dout_count <= '1';
elsif (pre_count_1 < pre_count_2) then
dout <= '0';
dout_count <= '1';
end if;
elsif (dout_count = '1') then
dout_count <= '0';
end if;
end process;
end count;
@W: CL117 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":75:2:75:3|Latch generated from process for signal dout; possible missing assignment in an if or case statement.
@W: CL117 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":75:2:75:3|Latch generated from process for signal dout_count; possible missing assignment in an if or case statement.
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[0]
@W: CL180 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":61:10:61:23|Found combinational loop at un23_data_sync
@W: CL181 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[1]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[2]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[3]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[4]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[5]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[6]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[7]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[8]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[9]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[10]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[11]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[12]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[13]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[14]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[15]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[16]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[17]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[18]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[19]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[20]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[21]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[22]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[23]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[24]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[25]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[26]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[27]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[28]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[29]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[30]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop at data_count[31]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[31]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[30]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[29]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[28]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[27]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[26]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[25]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[24]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[23]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[22]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[21]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[20]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[19]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[18]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[17]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[16]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[15]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[14]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[13]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[12]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[11]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[10]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[9]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[8]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[7]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[6]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[5]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[4]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[3]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[2]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[1]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_1[0]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[31]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[30]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[29]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[28]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[27]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[26]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[25]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[24]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[23]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[22]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[21]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[20]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[19]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[18]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[17]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[16]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[15]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[14]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[13]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[12]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[11]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[10]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[9]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[8]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[7]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[6]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[5]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[4]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[3]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[2]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[1]
@W: CL179 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop at pre_count_2[0]
@W: CL154 :"C:\Users\HQiEn\Desktop\Dominick\vhdl tutorial\shiftregister.vhd":31:2:31:3|Clock on register data_sync tied to a constant
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count_0_sqmuxa
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net un1_pre_count9
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[1]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[0]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":58:7:58:20|Found combinational loop during mapping at net count_proc\.un21_data_sync
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[2]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[3]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[4]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[5]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[6]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[7]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[8]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[9]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[10]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[11]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[12]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[13]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[14]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[15]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[16]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[17]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[18]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[19]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[20]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[21]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[22]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[23]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[24]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[25]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[26]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[27]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[28]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[29]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[30]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net data_count[31]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[0]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[1]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[2]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[3]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[4]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[5]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[6]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[7]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[8]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[9]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[10]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[11]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[12]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[13]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[14]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[15]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[16]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[17]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[18]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[19]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[20]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[21]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[22]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[23]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[24]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[25]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[26]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[27]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[28]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[29]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[30]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_1_1[31]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[0]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[1]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[2]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[3]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[4]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[5]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[6]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[7]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[8]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[9]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[10]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[11]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[12]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[13]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[14]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[15]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[16]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[17]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[18]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[19]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[20]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[21]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[22]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[23]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[24]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[25]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[26]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[27]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[28]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[29]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[30]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":42:2:42:3|Found combinational loop during mapping at net count_proc\.pre_count_2_1[31]
@W: MT462 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":75:2:75:3|Net un1_dout_count8_1 appears to be an unidentified clock source. Assuming default frequency.
@W: MT462 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":75:2:75:3|Net un1_dout_count9 appears to be an unidentified clock source. Assuming default frequency.
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":22:7:22:16|Found combinational loop during mapping at net un1_data_count_1[2]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net N_135
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[0]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[1]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[2]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[3]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[4]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[5]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[6]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[7]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[8]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[9]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[10]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[11]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[12]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[13]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[14]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[15]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[16]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[17]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[18]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[19]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[20]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[21]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[22]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[23]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[24]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[25]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[26]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[27]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[28]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[29]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[30]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_2[31]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[0]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[1]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[2]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[3]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[4]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[5]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[6]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[7]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[8]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[9]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[10]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[11]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[12]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[13]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[14]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[15]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[16]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[17]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[18]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[19]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[20]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[21]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[22]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[23]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[24]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[25]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[26]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[27]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[28]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[29]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[30]
@W: BN137 :"c:\users\hqien\desktop\dominick\vhdl tutorial\shiftregister.vhd":57:2:57:3|Found combinational loop during mapping at net pre_count_1[31]
@W: MT420 |Found inferred clock counter|clk with period 1000.00ns. Please declare a user-defined clock on object "p:clk"
