electronical
Hello,I have a problem,when I synt it with ISE I face with these warning:
when I searched in internet the same warning is occured when dont use them in port as output or never used them,but I used them why these warning are occured?
code
WARNING:Xst:1290 - Hierarchical block <Com_02> is unconnected in block <total>.
It will be removed from the design.
WARNING:Xst:1290 - Hierarchical block <Com_a> is unconnected in block <total>.
WARNING:Xst:1290 - Hierarchical block <MUX_index_1> is unconnected in block <total>.
WARNING:Xst:1290 - Hierarchical block <MUX_index_all> is unconnected in block <total>.
WARNING:Xst:1290 - Hierarchical block <MUX_a0> is unconnected in block <total>.
WARNING:Xst:1290 - Hierarchical block <MUX_a1> is unconnected in block <total>.
WARNING:Xst:1290 - Hierarchical block <MUX_a2> is unconnected in block <total>.
WARNING:Xst:1290 - Hierarchical block <Com_12> is unconnected in block <total>.
WARNING:Xst:1290 - Hierarchical block <Com_11> is unconnected in block <total>.
WARNING:Xst:1290 - Hierarchical block <Com_10> is unconnected in block <total>.
WARNING:Xst:1290 - Hierarchical block <MUX_index_0> is unconnected in block <total>.
WARNING:Xst:1290 - Hierarchical block <MUX_index_a20> is unconnected in block <total>.
WARNING:Xst:1290 - Hierarchical block <Com_min_s_0> is unconnected in block <tota>.
WARNING:Xst:1290 - Hierarchical block <Com_min_s_1> is unconnected in block <total>.
WARNING:Xst:1290 - Hierarchical block <Com_01> is unconnected in block <total>.
WARNING:Xst:1290 - Hierarchical block <MUX_index_a10> is unconnected in block <total>.
code
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use work.new_min_values_package.all;
entity CNP_VNP is
port( abs_Mes_v_to_c:in matrix1x7positive;
out_min_1_new,out_min_2_new:out integer range 0 to 127;index_min_new:out bit_vector(2 downto 0);
sign_value_new:out matrix1x7sign;sign_each_row_new:out integer range -1 to 1;
L_matrix_new:inout integer range -127 to 127;add_01:inout integer range 1 to 2304
end;
architecture behave of CNP_VNP is
type matrix1x4positive is array (1 to 4) of integer range 0 to 127;
type matrix1x2positive is array (1 to 2) of integer range 0 to 127;
component MUX_7x1
port(sel:in bit_vector(2 downto 0);in1:in matrix1x7positive;out1:out integer range 0 to 127);
end component;
component MUX_4x1
port(sel:in bit_vector(1 downto 0);in1:in bit_vector(1 to 4);out1:out bit);
end component;
component MUX_2x1
port(sel:in bit;in1:in bit_vector(1 to 2);out1:out bit);
end component;
component find_min_2_value
port(in1,in2:in integer range 0 to 127;out1:out integer range 0 to 127;ca:out bit);
end component;
component find_min_s
port(in1,in2:in integer range 0 to 127;out1:out integer range 0 to 127);
end component;
signal index:integer range 1 to 7;
signal flag1:bit_vector(1 to 4);
signal flag2:bit_vector (1 to 2);
signal index_0,index_1,index_2:bit;
signal out1:matrix1x4positive;
signal out2:matrix1x2positive;
signal out_s:integer range 0 to 127;
signal sel_0,sel_4,sel_6:bit_vector(1 downto 0);
signal sel_2,sel_5,sel_7:bit_vector(2 downto 0);
signal a0,a1,a2:integer range 0 to 127;
signal sel_3,index_a10,index_a11,index_a20:bit;
signal Mes_c_to_v:integer range -127 to 127:=0;
signal out_1,out_a:integer range 0 to 127:=0;
signal c,d:integer range -254 to 127:=1;
begin
Com_10:find_min_2_value port map(abs_Mes_v_to_c(1),abs_Mes_v_to_c(2),out1(1),flag1(1));
Com_11:find_min_2_value port map(abs_Mes_v_to_c(3),abs_Mes_v_to_c(4),out1(2),flag1(2));
Com_12:find_min_2_value port map(abs_Mes_v_to_c(5),abs_Mes_v_to_c(6),out1(3),flag1(3));
out1(4)<=abs_Mes_v_to_c(7) when length_row=8 else max_value;
flag1(4)<='0';
Com_01:find_min_2_value port map(out1(1),out1(2),out2(1),flag2(1));
Com_02:find_min_2_value port map(out1(3),out1(4),out2(2),flag2(2));
Com_a :find_min_2_value port map(out2(1),out2(2),out_min_1_new,index_2);
MUX_index_1 :MUX_2x1 port map(index_2,flag2,index_1);
sel_0<=index_2 & index_1;
MUX_index_0:MUX_4x1 port map(sel_0,flag1,index_0);
index_min_new<=sel_0 & index_0;
sel_2<=sel_0 & not(index_0);
MUX_a0:MUX_7x1 port map(sel_2,abs_Mes_v_to_c,a0);
sel_3<=not index_2;
MUX_index_all: MUX_2x1 port map(sel_3,flag2,index_a11);
sel_4<=not index_2 & index_a11;
MUX_index_a10 :MUX_4x1 port map(sel_4,flag1,index_a10);
sel_5<=not(index_2) & index_a11 & index_a10;
MUX_a1:MUX_7x1 port map (sel_5,abs_Mes_v_to_c,a1);
sel_6<=index_2 & not index_1;
MUX_index_a20 :MUX_4x1 port map (sel_6,flag1,index_a20);
sel_7<=index_2 & not index_1 & index_a20;
MUX_a2 : MUX_7x1 port map (sel_7,abs_Mes_v_to_c,a2);
Com_min_s_0: find_min_s port map(a0,a1,out_s);
Com_min_s_1:find_min_s port map(out_s,a2,out_min_2_new);
end;
